Self-diagnosis for air con
elmo298
GB
accord 2.2cdti
Hi guys,
I saw some of the non-sat nav versions have a air con self-diagnosis. Still have much trouble with mine not working with the summer coming back round, wondering if the sat nav version has something similar?
elmo298
GB
accord 2.2cdti
Yeah, unfortunately I'd need pictures as I am not that knowledgable and they're all gone :(
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
It was more a description of the path you should take, eliminating components in sequence before splashing out on something expensive.
Have you tried swopping over the two relays in the fusebox under the bonnet (or just tapping them hard with the end of a screwdriver )?
elmo298
GB
accord 2.2cdti
Yeah I even bought replacement ones on Amazon with no luck. If you put power through the relays it kicks in the garage thinks its something to do with the centre console but no one else here has experienced that
elmo298
GB
accord 2.2cdti
Update: Managed to access the hondaESM and self-diagnostic, reports that the AC is communicating with the display unit therefore suggesting its something mechanical I guess.
