self leveling headlights
Richard B
Australia
2006 Tourer
Mk7 Question:
Is the self-leveling adjuster (the motor part) that adjusts stock HID headlights according to suspension input the same unit that adjusts the position of headlights in the wagon?
Richard B
Australia
2006 Tourer
OK they both have the same part number 62SEA02B so I guess they are the same thing.
This puzzles me a bit, as I find the dash operated headlight adjuster to react slowly to changes in settings. I would ***ume that a HID leveler would need to operate more quickly. Unless of course the adjustments it makes are very slight.
Anyone with stock HID's have any input? Do you notice the self-leveling action at all?
Kaput!
BOLTON UK
04 accord tourer 2.0
I had no idea the headlights did auto adjust on the mk7 accord (maybe a facelift upgrade?).Anyway i have a pre facelift tourer with stock and they seem to remain fixed unless i raise beam up/down from the leveller dial to the right of the steering wheel.Just to add adjustment from within car is instant and precise no issues
mlkehunt
Norway
08 I-CTDI sport
only HID lamps self level, EU/EAA regulation. they must also have washer nozzles.
I have been curious about the same thing as it seems too slow, but perhaps the manual control has a regulator. searching for info about the US TSX is no help as they are not required to have self leveling HID's
the only differences between the hid and halogen lamp units is that the cutout for the igniter is blanked on halogen, and the hid projector is vastly different to the halogen one.
Kaput!
BOLTON UK
My executive has the washer nozzles but not HID fortuately.Im actually one of the few that are happy with my light output of my halogens,the nightbreaker bulbs i fitted made a huge difference.Btw i disconnected the pump to the headlamp washers as they consume a stupid amount of water.Got fed up of filling water bottle,sometimes daily,now better.
Richard B
Australia
2006 Tourer
A much earlier owner than me wiped out the front of the car and replaced the front bumper with an earlier non-washer type but left all the hoses in place. I just figured out that new washers and caps are quite cheap direct from China and that it won't be hard to retrofit them. But I will put a relay on the pump so they only work when the driving lights are actually on.
I'm not happy with my driving lights. The high beams are good but with 80% of cars facing me at night running two or 3 times the light output I have my vision gets washed out all the time. Upgraded halogen bulbs like nightbreakers are OK but burn out in under a year, so I end up with at least one "spare" bulb in there at any one time quite often.
BTW, "upgraded" 55W halogen lights like nightbreakers aren't anything magic. Measuring the current they draw it turns out they are actually more like 70 to 80W bulbs., so the wires are getting warmer than they are meant to. How they manage to sell them as "legal" 55W bulbs I have no idea.
I figure that either the motors can do more work according to type of input, or that the amount of practical adjustment required for ordinary road conditions is actually very small. I suspect that Honda set up the leveling system to not constantly react to small inputs so it doesn't wear itself out. The motors are an obsolete part nowadays so I guess there wasn't a large demand for them as parts.
I want HID's, and from posts on this forum, the projector in the Mk7 headlight gives a sharp enough cut-off in the beam pattern for H1 replacement HID's to work nicely. But running aftermarket HID's is a defectable offence here, unless you have washers and levelling. The OEM levelling system on the Accord is a little complicated, but the test procedure for the adjuster motor is in the workshop manual. So my next thought is to figure out if I can set up a couple of ultrasonic sensors in a front and rear wheel arch that link to an Arduino that then commands the motors via a differential input algorithm or lookup table.
mlkehunt
Norway
08 I-CTDI sport
Hella sells or used to sell exactly that but it's going to run you about €350. Iirc the kit comes with a control box, a set of stepper or servo motors depending on your choice of kit, as well as an ultrasonic sensor variant or lever arm sensor variant for you lower control arm or damper.
Hella 8XX 008 614-011 the part number for the ultrasonic variant(I think). no good info on these online, retailer might be a better bet.
The DIY option sounds more interesting though :p
it is sharp but it is not HID sharp. I have morimoto h1 xb bulbs in my halogen projectors and it's still got the blobby halogen hotspots as opposed to the sharp yet filling light of a proper HID projector
top is mine, h1 retrofit, bottom is TSX d2s. not a perfect comparison
