spare wheel securing
trolleyjack
Kent
Accord D 2.2 Exec
Afternoon gents
I have a full size spare wheel rattling about in my 04 diesel tourer, does anyone have the part numbers for the securing /clampdown bolt and washer, (they are showing in the Lings diagram L29 but not in the price menu ).
Alternatively, do the securing bolts/ washers for any of the other models ie civic have the same thread and the same fit.
TJ
I just rummaged around my garage until I found a bolt that fitted and drilled a hole in a metal bar and that was enough.
My 8th Gen spare is held in place with an M8 x 80mm bolt. I can't promise the 7th gen is the same, but I'd be surprised if it wasn't...
http://jmp.sh/Kh2W4mL
Thanks for the replies gents, I've got it packed out with towels but it is moving vertically, very bad roads here the 8 mm bolt option seems the way to.
TJ
8mm bolt sounds right. I just used a standard bolt as I knew the Honda toolkit has a 13mm spanner in it which I will always have handy to undo it.
