Stereo fuse location
Blippi
Manchester
Honda Accord GT ES
Hi can anyone confirm where the fuse is for the stereo system. The new owner of the car has had the stereo stop working after the main starter battery was replaced. Location 17 and 18 are both listed as acssesory. Anything else it could possibly be?
The head unit itself isn't coming on with it being the ES GT don't think it has the separate amp.
Fuse no. 18 (7.5A) in driver's side fuse box is ACC signal for the audio unit without premium audio system.
Fuse no. 16 (7.5A) in driver's side fuse box is ACC for the Audio/HVAC display unit. Dashboard lighting is fed from the center unit through fuse no. 6 in passenger's side fusebox so if that works and fuse no. 6 is fine then that's getting power at least.
Thanks for the quick response much appreciated I'll update when I've tried it
