I did mine and it's not that hard. It's also quite similar to the one in the video.
If you are ok with your tools, then you should have no problem, but you will need a tool to lock the crankshaft a really good quality socket wrench together with extension bars to remove the crankshaft bolt, it's really really tight.
This is the guide that I used, it's quite straight-forward:
http://honda-tech.com/showthread.php?t=1908944
