Swervin Mervin
It moves into the closed position automatically but rebounds and lifts again when it should click shut. There is nothing obstructing it.
Anyone?
Anyone?
Is getting itself right into where it needs to be or stopping maybe a few cm short? I'm only wondering if it's the struts? If it's getting flush and then not engaging the latching mechanism, I've not heard of that one before. The faults with the boot tend to be centred around the motor and/or the struts.
Edit: Could it be the lock and closer ***embly, part 11 in this diagram:
Not cheap at £341, although I bet you could fit it yourself saving on labour.
How are you closing it at the moment ?
Does it stay shut if you close it manually ?
