Just to clear up a few myths here guys.
There is no point in trying to recitfy a problem if you don't know what the cause is.
If your warning light is on, it means the ECU has picked up a problem. You need to have the code read first and then decide if you want to do a DIY repair.
ABS sensors are not removable in this generation of Accord - they are prone to seizing, and as I will have to do myself this week, will need drilling out.
It might not even be an ABS sensor.
Regarding the chat facility on this forum, that is reserved for the Admin team.
