ExpandWeiner
I'm the proud owner of a 2004 EX-L Accord and this happened a hour ago. So I parked on my usual spot and switched off the car. Came back a hour later, turned on the ignition, all the lights lit up and turned off as usual, started it up and half a second or so later all three lights came on at once. I drove for around 15 minutes with the lights on. I had to stop for a little bit and after starting the car, the lights remained for 10 or so seconds and turned off. They haven't come back since. I used my scan tool to check if I could get any hints, but there were no fault codes. Kinda puzzled on this one and I would appreciate any help
