WHAT IS THIS? OIL AND COOLANT? :(
ted7777
Accord
Hey Guys, Honda Accord 2004 2.0l, i was changing tyres from winter ones to summer, and saw this weird mixture it seems like ( oil + coolant )? but it is near crankshaft pulley, and i don't see anything more where it could came from? I'm attaching picture how it was as i saw it first time.
ted7777
Accord
Are you losing a bit of grease out of the CV joint ? If so the boot might need replacing.
you think that could be rubber of CV joint? Because i cleaned everything, and After 10km drive there was a little drops of that white mixture around, but cv joint rubber is absolutely dry ?
ted7777
Accord
SayamaAccord
And still...
County Durham
13 Tourer 2.4 EX man
If the boot itself isn't split the grease can still come out the end if the seal has gone. I once got away with a new clip but if there's dirt inside the boot or the boot material has perished over the years so it can't seal properly any more then it needs a new boot.
