What went wrong
IrishGirl
Ireland
Accord 2.2 i-dtec
So i bought this car 2009 2.2 diesel 150bhp accord couple of months ago. 76k miles.
Anyway going to work this morning car was fine starting off. Then once i got on the motorway and accelerated i heard a pop and then she started pumping white smoke out the exhaust and the DPF clogged symbol came on before the CEL. Engine vibrating like mad and making a really bad constant clicking noise the higher the revs. Said id try drive to next exit to get off the motorway but she then died
So had to pull over. She'd start after that but i got a tow truck to bring her home as I didn't want to cause damage.
Now i drive nearly 40 mins twice a day on the motorway normally sitting on 80 miles the majority of the way and no dpf regeneration light came on.
Any guesses?
Any idea?
Sounds like this now
https://youtu.be/Vf4x_HL7jDE
IrishGirl
Ireland
Accord 2.2 i-dtec
edgeoftime said:
Sounds like an injector out of it's hole??
Have a mechanic coming tomorrow to look just wanted to know if it's bad or a rough idea what it is
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
That would require unscrewing, unless there was a serious fuel lock on that cylinder to take out the threads in the head.
Must be the copper washer/seal if it is anything like the iCTDI
IrishGirl
Ireland
Accord 2.2 i-dtec
Nothing looks out if place in the engine bay. Injectors look fine ie haven't popped out or anything. No pipes off or anything.
Just that really bad knocking noise in the video and plumes of white smoke out of the exhaust and there is a really strong smell of fuel.
apintofmild
Yorkshire
Golf GTD
What did your mechanic say? Could it be a burnt / broken exhaust valve?
edgeoftime
Waltham Abbey Essex
11 idtec tourer ex.
Diesel knock, one of them is not working?? on old fashioned engines we crack the feed line and listen for drop in revs, whichever it is causes this is a suspect injector, no idea about these electronic gizmos though.
Sysek
Accord MK7 2.2 CTDi
Hi Irish girl
Any resolution on your issue?
