Where to connect heated car seats?
nodrogs
N. Ireland
Honda Accord 2.2
I'm thinking of retro fitting heated car seats. Where would be the best place to connect the power supply? The ones I've looked at have a pre-wired "loom" (they don't connect into the cig lighter).
Thanks.
crespo
Bournemouth
Accord EX 2.0 i-vtec
Just cut the loom and find the positive and negative and attach it to any switched 12v supply like the ignition switch and ground the negative to the chassis. pretty simple really. Not sure about the heated side of things but to get the things moving any 12v supply will do.
jayok
TA Friends
Ireland
CRV / S2000
The heated seats put a significant electrical load on the car. Make sure you do this right!
1. If in doubt draw power directly from the battery +ve pole via a correctly rated cable put a correclty rated fuse in series here (nut sure but say 30A as an example)
2. Pass this to two separate relays that can only be engaged when the ignition is on and the relevant heater switch it pressed
3. Feed each seat from the relay and put another fuse in series to each seat (15A) each
4. Secure each connection and insulate correctly.
nodrogs
N. Ireland
Honda Accord 2.2
I'm looking at this kit, just for the driver's side:
http://www.waeco.com/ae/4381_5964.php
Reading the instructions (although not 100% clear), it seems that you connect one wire to the battery, another to a switched connection (e.g. 12v socket?), and the final one to ground. The kit comes complete with a harness and relay (so I ***ume the relevent wires are fused)?
jayok
TA Friends
Ireland
CRV / S2000
Ah ok, so it's not a Honda retro fit.
Looking at the product, the maximum wattage is 45W or approx 3.76A at 12V. A 5A fuse will cover this if not supplied, so just put one between the power source and the seats if not included.
Why? Well if the elements break in the heater which is accidentally possible you don't want a short current down the wires. If not fused, just stick one in.
nodrogs
N. Ireland
Honda Accord 2.2
Thanks Jayok. Yes doesn't seem to be a massive power consumption. Would be a different matter I guess if I was doing both front seats. If I go ahead and do this I'll try and put together a DIY guide. Have to see how easy it is to get the pads between the sponge and seat cover without having to dismantle the whole seat!
