Wing mirror indicator lens
apintofmild
Yorkshire
Golf GTD
Some kind soul has smashed my mirror indicator lens. Thankfully that appears to be the only damage.
Has anyone replaced this bit? Is it even a separate part?
I need to weather proof it as-soon-as before the LEDs start corroding.
With a little advice from @edgeoftime I've got into it :D
I'd hoped the missing bit of lens was inside the somewhere, but it's not. Making a repair might be tricky, the damage is more extensive than I feared, but I'm loathed to throw £60 quid at it for a new one.
Complete mirror ***emblies are fairly scarce, and so relatively expensive, so I doubt I'd save much by getting a scrapper and selling on the bits I don't need.
Anyhow, should anyone else need to do it:
Move the mirror glass (either by motor or by hand) so the outside bottom corner is as far forward as possible.
Shine a torch between the glass and the shell and you'll just about see the white support frame.
Use a flat blade screw driver between the frame and the glass (the glass has a black plastic backing plate so it won't damage too easily) to gently twist / prise the retaining lug free.
There's one on the inside bottom corner too, but that released with a bit of twisting (no screwdriver required)
There is a small amount of chewing gum like black goop between the glass and the support frame.
To stop rattles I presume.
This pulled away without too much effort.
The top of the glass is held on with hooks rather than clips, so once the bottom is free the glass needs to be pulled down and out.
I left the de-mister wires connected for what I was doing, but they could be removed if required. A bit of tape might be an idea to stop them shorting together.
Access to the LED indicator module is by removing 4 self tapping screws and drawing the inner shell forward over the motor ***embly.
The indicator more or less falls right out from there. It's somewhat bigger than it looks from the outside.
Re-***embly is just the reverse.
Once the top of the glass is correctly hooked in place slip your forefinger behind the glass onto the support frame and with a pinching motion use your thumb to press the glass into place until the clip engages.
Fixed. How long for remains to be seen...
With the lamp ***embly removed I solvent welded the cracks in the white (ABS) rear, glued all the loose shards of clear acrylic to each other and to the rear shell. There's glue all over the face of the lens, but that's ok.
Once all that was dry, I tidied up the triangular hole in the lens and cut a matching piece from 4mm thick acrylic sheet.
and glued it in place, so it stood proud of the rest of the lens
Next I shaped the flat repair section with a file, followed by finer and finer wet and dry (like you would with body filler) so it roughly matched the contour of the rest of the lens
Then I polished it all up with Meguiar's scratch remover and refitted it in the mirror housing.
Not as nice a new lamp, but having just bought a battery, rear brakes and two tyres the £60 quid saving is welcome.
It's weather tight at the moment (I pressure tested it down the electrical connector before refitting, and there's no leaks).
Time will tell how it will stands up to weather, vibration and car parks (!)
Put the saved pennies into a couple of HD cameras facing rear and front offside and permanently recording, just so you can nail the cnuts that think they can get away with something like that.
A stirling repair job, I doff my cap to you.
