winter wheel and tire options?
welderinahonda
Honda Accord
I have a 2009 Honda accord exgt 2.2idtec,
it has 18'' alloys currently fitted.
I need to fit the car with winter tyres.
I'm thinking 16 rims with appropriate tyre to match original diamater and ratings.
I'm wanting 16's for a more forgiving ride narrower diameter for driving through eastern Europe on rough roads.
does anybody have experience or knowledge from doing this and recommendations on which wheels and tires.
am I able to fit alloys from a civic or crv which run 16s''?
or should I go for steel wheels.?
or should I go for accord 17' ' alloys?
also the car is from UK I'm not aware of it having (tpms) does anyone know how I can check, and if it does how I can get around any potential hurdles with a 2nd set of wheels.
Many thanks in advance.
What size wheels will fit over the brake calipers on the front will be the biggest concern.
I purchased a set of 17" for my ATS 2013 for winter use, these clear the calipers on the 320mm discs no problem so you may be able to use 16" wheels.
Personally I would go for a set of cheap alloys oem if possible and just use them as winter wheels.
You won't have TPMS on a 2009 car.
