Accord 2007 bluetooth hf module location/ where is it so that i can disconnect it ?as battery goes flat in 2 days
switchx2
Honda Accord 2007
Hi Can anyone guide me to where the Bluetooth hf module is located so that I can disconnect it or isolate it by pulling a fuse? As my battery goes flat in 2 days.
I had this very same issue with my 08 Accord also had to disconnect it.
I found the Bluetooth hfk under the clock,/climate control display on top of the dash. I used 2 metal paint scrapers on each side to slide thr cover forward and disconnected the green connector by pinching the middle latch. Also dresolered the display connector as that worked now and again.
Glad to help
