r3dd3v1l
£3000 grand so i can buy airbags and some wheels if your offering?J4JAV said:No problem mate. If you need anything else just let me know.
hahaha
Thank you for your order Tom. We will keep you updated via emailOsiris said:Cheers for the info in this. Order has been raised to overhaul my interior lighting!
Hi Andy,AndyHK said:Hi, some of the bulbs like T20/7440/3156 CREE LED 50W didn't state as a pair, is that really £19.95 for a single bulb?
Sorry but I think this price would be too steep then
Do I need to drill a hole at the front fog light cover for wiring if I go for the H11 HID kit?
Here is the link for the resistors: -AndyHK said:Any link for the resistors?
I've 06 facelift one.J4JAV said:Sorry I missed this Andy RE: your H11 Fog HID Conversion - no you will not have to drill any holes as the HID bulb has a H11 fitting, so its a matter of taking your old bulbs out (twist) and in goes the HID bulb, and then its a matter of connecting it to your ballast and fog light connector wiring block.
May I ask exactly what model of Accord you have so I can be sure that these will fit a HID kit... as the pre facelift diesel Accord's did have a rather small fog lamp unit.
i rarely ever use the glove box so no issue for me hahaha, cheersbrett said:Yes mate all the same LEDs.
The only differce is the vanity lights has 2 lamps in each side and the glove box has a small led that I haven't looked at yet.
Hi Jav, yes all the items are for my 06 Accord. I also left you a note about resisters, because the website didn't say which watt should be use for front and back indicatorsJ4JAV said:Hi Andy,
I have got your order through. I need to check it all and make sure you have ordered the correct things... just to confirm this order is all for your Accord right?
Stevie91 said:Hi mate just thought I'd ask as I may be buying from you in the future.
I have changed my sidelight bulbs to LEDs, although the first set I got off eBay were too blue. I ordered a larger set with more smds and fitted them the other day. When they were on they were 100% white, but after putting them in the sidelight housing they seem to have a blue tinge to them, almost xenon coloured.
I know the facelift lights have blue housings but mine is a pre. Could it be because my car is Arctic blue? The LEDs I have tried have ranged from pure white to other such names but all end up with the hint of blue. Any help would be greatly appreciated. Cheers!
PIC:
