Hey Guys & Girls,
Sorry its been a long time since we last posted on here, hope your all doing well! We now have the H1 Cree LEDs in stock and we have tested this model too. They were tested on a 2007 Honda Accord, which had the same issues as the Civic (the rather tight H1 bulb opening, which wouldn't allow previous H1 generations to be fitted). Here is the new range of the H1 LED Headlight kits which we now stock: -
http://www.horizonleds.co.uk/exterior-leds/cree-led-headlights/h1-led-headlights-headlamps
Here is the bulb kit used in this test: -
http://www.horizonleds.co.uk/exterior-leds/cree-led-headlights/h1-led-headlights-headlamps/h1-cree-led-headlight-kit-gen1
The difference between the two is firstly the design, the Generation 1 is a fan based kit and the Generation 3 is a copper heat dissipation belt based kit. The Generation 1 uses Cree LEDs and the Generation 3 uses Philips Lumileds, the brightness is the same for both and they both will fit the Civic.
Below you will see a video which we have made to show how they perform. Of course in reality these are much better, a video only can show a limited amount. The issue we had with these is that we cannot flash the main beam only without the dipped beam switching on too, seems most Honda's operate this way.
So we let the HIDs cool down fully hence why you can see the discoloured blue/purple startup effect as they start to warm up when we flash the main beam. The pure white is the main beam, further in the video you will see the distance these can reach when activated. The furthest sign post (black and white arrows on the roundabout) is just slightly over 0.4 miles according to the trip computer.
https://www.youtube.com/watch?v=SqTghPb1smM&feature=youtu.be
So in a nutshell although they are not extremely over powering as HIDs which used to be in the main beam, but they are purposeful as they can be used for flashing and there is no warm up time like HIDs, even the Fast Start HIDs we sell will not warm up quick enough to flash, something which a lot of drivers in the UK tend to use. Also when you use these to flash the LED driver does not get damaged over time like the HID Ballasts, so its an all round good product especially for those who want to match their main beams with their Xenon HID kit.
Now you may be wondering which one to go for, well the Generation 1 is only available in 5000K and the Generation 3 is available only in 6500K. Depending on your HID kit, you have a choice here, but if you have OEM factory fitted xenons then the 5000K is going to be the best match.
As always if you need any help or information, just let us know. For further enquires or order enquiries you will get a faster response from
Forums@HorizonLEDs.co.uk, as we don't always monitor the forums as regular.
Currently at time of posting this we have stock of the Generation 1 H1 available, the Generation 3 does have some delays and is on pre order only. We will be getting this back into stock very soon, but please email us for a more accurate date as we are still taking pre orders for this as we speak.
Thanks for reading!
Horizon LEDs
