Hi
Car doesn't get used much at the moment but have found that the air con has stopped working.
Can hear (and see) that the compressor is being engaged correctly but just no cold air.
Does the fact that the compressor is being engaged rule out the high + low pressure switches ? ***umed they would stop it running but not sure if that is correct.
Haven't noticed it becoming worse over time, last thing I remember it working as required but couldnt say when that was to be fair.
Any ideas, suggestions on things to try.
May need a re-gas but would have thought if needed then the low pressure switch may be activating and therefore stopping the compressor but unsure ?
