Hi, ive got an Accord IDTEC 8th Gen - had this for 3 years.
I have a problem with my air con.
All worked fine then one day air con just stopped working. I plugged Honda HDS in and it said pressure sensor - open circuit. i replaced the sensor, had it regassed and it still wouldn't work. Clutch doesn't engage and no fans come on.
Plugged it in again the fault had gone but it says Thermal pressure sensor on (this is not in the DTC section its in the heater system) - i haven't a clue what this means and dont know how to turn it off.
All fuses and relays are fine.
Currently have no gas in it whilst im testing it so had it emptied.
I rang an air con man who said you can reset the system on the dash - again, ive tried (only thing i can do is where it goes through the heater test - but mine stops half way through).
Any ideas of anything else i could try.
thanks in advance
thanks in advance
