The green plug is for the boot light. with a orange wire for negative signal when boot open and white wire is 12volt connsant. it plugs into the light on the boot.
maybe i wasnt clear earlier the blue plug comes comes from the mechanisum and it is the 1 that sends the negative signal to the oarnage wire and to the other boot light.
hope this makes sence.
Steve - I'm sure the tab that Tin-Man pointed to will manually unlock the mechanism. I have got a spare in front of me and if I move the arm it will engage/disengage the handle mechanism to "catch" the latch.
This is done via 2 white plastic arms - 1 attached on the mechanism and 1 attached to the cream motor housing. Could it be that these arms aren't joined any more at the pivot point? You may be able to get your fingers to the arm attached to the mechanism and move it enough to engage the handle.
Based on Tin-Man's reply with the voltages I have just had another look at my car. With the boot open I get absolutely nothing until I unplug the Blue 2-wire connection. Then I get the following:
White/Red - 12v briefly when locking
Yellow/Red - nothing when locking or unlocking
Grey - 12v constant only when the car is locked/deadlocked
With the boot closed (Blue 2-wire connected) and me attempting to fit in the boot I get the following:
White/Red - 0.5v briefly when locking
Grey - nothing
I cannot find the Blue 3-wire plug that Tin-Man pictured - can you please point out where it is in relation to the grey or Blue 2-wire connector? I can then check to see what I am getting from that.
I checked the voltage of the Blue 2-wire and get nothing when locking or unlocking - I don't know if this is correct.
One other thing - is the grey latch directly above the bumper anything to do with this? The one with the black plastic uprights on either side. Mine is slightly off centre and I don't know if this has something to do with the detector to check if the boot is closed - I'm clutching at straws here.
Exactly the one (except mines a bit worn).
I went out and tried holding it down and the boot lid popped up!
Chuffed with that!
It'll be a good party trick to show the other half when out shopping
FIXED IT!!
At last! As I was fiddling with the lock mech (boot still firmly locks) from the inside of the boot I felt there was tension on the latch near where it strikes the lock. At first I ***umed that it would only push that small distance, but when I was ***essing the other lock I bought earlier this year I realised that a little extra force would strike it. I instantly changed it for the replacement lock mech but, since playing with the offending lock mech, I can find no obvious reason why it wouldnt work!?!?!
Either way though...ITS FINALLY FIXED!
I am also no longer selling the car as the one I was gonna buy off my Dad is going to my brother as he is likely to pass his test soon. So I shall be annoying you all some more for your knowledge on various little bits.
Cheers for the help with this issue!!
thats awesome your keeping the car!
oh and good you got it fixed too lol
Looks like good news all round.
Following the tip to check the rubber grommet I found two wires snapped completely (going to the grey motor plug) and 3 with the sheathing wearing out. Some bullet connectors (I can't solder for toffee) and a lot of insulating tape later I also have a working boot lock!
Thank you very much for everyone's help - especially Tin-Man with the detail & pictures.
Cheers.
Hello
Hope I am able to get some more info if possible.
Yesterday was at this all day......
Checked continuity from the grey plug all the way down to the glove box area. Everything seemed fine. Also took the boot lock motor apart and tested that the motor works. It does.
Utterly stumped. Once plugged into the grey box behind the glove box, where does the connection go?
