I have had a search in the forum but cant seem to find anything so im sorry if it already has been covered. I have a couple of questions, how much fluid is needed to change all the fluid in the clutch? and how much fluid for the brake system? also have i located the correct bleed point for the clutch in the pictures below? Thanks in advance.
The clutch takes very little, but there are recommended capacities, you'll probably find most of us that's done this already, keep flushing 'til it's clear, so I'd suggest getting two 500ml bottles possibly three..to be sure.
You location for the bleed nipple for the clutch is a bit vague in your first photo, but spot on in the second....
