J4JAV
Mr OCD Detailing
Hi Guys,
As many might know and remember this from the last site, I thought it would be good to have this on here also, so guys here is the write up for my full LED conversion which was my first major mod to the new car which I did last winter. Hope it helps many of you and doesn’t upset some.
First of all here is a simple outline of what you will need to buy to do the conversion (P.S ignore the ‘please note’ section below as I have now completed my 100% full LED conversion!)
Here is how most of the kit will come, or packed as, all these can be bought on eBay just type in the bulb type followed by colour, but I do recommend going for the SMD High Power LED's as these are going to be your important driving lights and you want them bright and to work all the time 100%.
This is the nice and easy ones, the small tube lights for the sun visors... with a small tiny flat head screwdriver simply remove the cap and pop out the old bulb and in goes the LED one, it will be a bit of a tight squeeze but it will fit, size is 31mm, before and after shots shown below...
Front festoon lights also just clip out, many already know this, these are a definite to do mod as them standard bulbs tend to blow quite often…
