Update, with more information. So they say that when investigated, the car gave them no faults, even though the fault light on the dash for DPF! was on. They say that is because that comes directly from the Pressure Switch. Is that true? They also say that the car had not re-generated itself in 700 miles, which they could see from the log and that it was their forced regeneration that was done 700miles ago. They forced it to re-gen again and it did with no problems and the soot levels went back down although they say it does seem to be putting a lot of soot into the filter, So another question is, they say they updated the software 700miles ago when they put the new DPF in, is that not the most likely cause of the problem? Can an ECU partly fail? The car goes perfectly, as I have said before over 60mpg.Also they say it is supposed to regen every 300km. therefore it had missed at least 2. Is that the only signal it gets to do that, i.e. just looks for the distance and nothing to do with the pressure switch? As the forced re-gen works I have ***umed mechanically everything works and there are no wires hanging off / bad joints, is that a fair ***umption?
Any advice gratefully received.
