ROAD DETECTIVE
Have been having a problem with the plastic headlight lens covers dulling with a rough outer feel to the plastic. This was mostly occuring in front of the dip beam, so it must be heat related. It must have been blocking some of the light getting out on the road to a degree. Went to the local car accessory shop and they recommended I buy Xerapol Acrylic Scratch Remover. Started with a bit of the wet and dry paper supplied in the kit. Then a few minutes rubbing with the compound from the tube. A quick wipe with a clean rag and hey, what a result. They are like new lens covers again. Very impressed with this product. It's also for other uses such as wood trim, motorcycle screens etc. In the past I have tried meg x scratch remover for body work and got some improvement, but not half so good as this product, which is specifically designed for the clear plastic. Hope this helps somebody with the same annoying problem.
