CarlStewart
Is there an easy way to do this? - as per my previous posts have an annoying rattle that may be pulley bearings (i'm on longer drive belt).
An alternator guy looked this morning and suggested I remove the pulleys and he can repair them (would you advise to do this??)
So just need to know if it is just a case of accessing the tensioner bolt and then slipping the belt off (I can then run with belt and see if noise persists), if not I can take pulley's off and get repaired (or go for the shorter belt).
Carl
Carl
