Nope, you can do this with pre-facelift models as well. I done it with my 2.4 as it was over optimistic by about 2 degrees. To do this hold down the odo reset while turning ignition to (II) and keep holding until the temp goes changes from -3 -> +3. It will cycle through the numbers and when it's right let go and it's saved.
So, for example, I measure mine and it was constantly over-reading by 2 degrees. So, when the outside temperature was reporting 7 degrees, I cycled to minus 2 and saved. It then reported 5 degrees.
