Tafia
Hi folks,
Though my 2004 Accord with 84,000 miles passed the MOT a month ago, I now see a fluid leak has appeared. It leaves a mark on the ground below the offside headlight and the fluid seems to be lost from the power steering system.
I top up the resevoir and it slowly drops, not a lot but enough. The steering appears unaffected and there is a pipe which leads from the upper part of the reservoir and down towards the suspect area. The fluid is obviusly dropping onto metalwork somewhere and running along it before hitting the ground.
Anyone else had this and if so what was the cure? I can not see where the leak is coming from as the pipe I suspect disappears from view.
