Hi, I recently bought a HID kit and when it turned up I couldn’t get it to fit. The bulbs wouldn’t fit through the hole in the housing they had a metal shield around the bulb and I’m now thinking that I was meant to remove this, it’s the same as the one on the far left in the picture in this link http://www.rclick.co.uk/product_info.php?cPath=72&products_id=974 did anyone else have troubles fitting thier kit and what did your bulbs look like? Also I did read on here at some point that led bulbs can cause interference with the diesels, is this correct as I’m wanting to do a full led conversion?
