High resistance - passenger airbag
horsemeatscandal
2002 Accord Euro R
Hi all,
Had the SRS light on (intermittently but mostly on) over the last couple of weeks. Had the code read and came back as high resistance on passenger's side airbag. Dealership I bought from are covering repair under warranty but I'm just checking(/hoping) if maybe this is a common one with a quick fix i.e. a loose connection somewhere?
Don't have the exact fault code at hand but I can get it if it helps. It wasn't the dealership who read the code but a local Honda specialist.
Thanks in advance.
It can sometimes happen if the seat has been moved a little forcefully. Check your yellow plug connectors below the seat are securely fastened and plugged in cleanly
Thanks for replying. The connection under the seat appears to be fine. They probably already checked all the connections to be fair, thought I'd maybe get lucky.
