Hi everybody...I'm a Honda fan for many years now...
Just bought a accord diesel estate 2.2l 2005 and I noticed a heating problem...
The heating at passenger's side works perfect while on driver's side is much less (but I do have the airflow coming).
I did the following:
Costa
- Removed the heater water valve, checked, working, refitted (but I disengaged the control wire leaving the valve full open position for testing)
- Checked pax side actuator... (mode actuator), tested, works perfect!!
- Removed driver's side actuator, tested, works perfect, refitted. I even tested manually the plastic groove to the upper position, no change to the issue!!
Costa
