Kyash
Hi All,
First time posting (on any site!) so please... be gentle... :blush: This is a bit lengthy but I want to cover everything.
Ok from the beginning - I have a '54 Accord 2.2 ctdi and it's been great so far. Done 125k miles and I was running it for about 18 months using a Pro-Bitz eBay special Mod Box
Since last Winter it's been getting progressively worse starting until one day wouldn't start at all. Battery got changed and everthing was fine for a while. I removed Pro-bitz box as precaution.
Beginning of Summer it was getting worse.
Crank 2-3 times in the morning -> start.
Afternoon maybe 5-8 times -> start.
After a long drive (I work 90 miles away) I would leave it around 15 mins and crank 20 times, most times take 2 or 3 attempts. A couple of times refused to start after 5 - 6 attempts.
Came to a scary head when accelerating hard in 3rd gear on Dual Carriageway: got to 3000 rpm and engine coughed, spluttered and died EML on - Glow Plug light flashing... managed to coast off slip road during rush hour, engine off, waited a minute and then engine started again
EML stayed on for around 20 mins then went. Put a borrowed code reader to it and got P1065 - Manufacturer Control, P0087 - Fuel Rail / System Pressure too Low, P16A4 - Manufacturer Control.
Obviously big problem so took it to local garage who reckoned I needed filter changing. Generic £15 filter fitted :blush: . They asked if I wanted an additive adding straight to the filter which they use to help cars pass MOT emmissions - I though why not? Started no prob at the garage - happy days! Thought I'd treat her to full tank of VPower as well.
Took it to parent's house and then after half an hour point blank refused to start! :angry: Rang garage and they suggested I bleed the injectors so slackened one-by-one while someone was cranking and got it going.
Did some serious digging online and found this site and thought I realised error of my filter buying ways... ordered genuine Bosch / Honda 16901S6FE02 Filter from local Holdcroft through eBay (£32 vs. 45 - one of the workshop guys even delivered it my door! seller ID 2006holdcroft). This arrived last Thursday and I fitted myself following one of the guides on here (although I cheated a bit by not taking Air box / throttle ***embly off, removed one blot from left side and slacked all the other bolts I could see on the bracket - and then loosened the rear bolt after tilting the whole bracket forward).
Ok, so after 2 or 3 rounds of bleeding air and priming it started a dream! Since then no problems until yesterday - same thing with hot start at Hilton Park services. Got home and bled the filter again (bit of air came out), started great again. Today again no prob in the morning, complete nightmare when I stopped at some shops on the way home - as bad as it was before took 3 attempts to start! This time I got home and slackened the injector side while someone cranked, didn't notice much air coming out though. Now it starts OK.
Please please help! Wife is 7 months pregnant and I'm losing sleep thinking about this happening when she's in labour!!!! I'm not in position to trade it in yet and otherwise love the Accord...
I think it's an air-in-the-fuel-line problem but can't think where to start looking. Checked all the hoses and connections I could see and they all seem sound.
Could it be EGR? I want to give it a good clean anyway - can anyone suggest a good cleaner?
Shall I just carry on bleeding the air?
What should be my next step?
Kash
Kash
