I went to strip and clean my binding NS front brake caliper and the retaining bolts/pins under the rubber caps are a torx fitting, not the 7mm hex I was expecting, anyone know if there was a design change or if it's a replacement caliper (its ATE)? If anyone has an idea of the torx size I'd appreciate it as well, it's somewhere between a T40 and T50.
Ian
Ian
