P0122 fault code
Werebear
Honda accord 2.0
I have just had a P0122 fault code show up on Accord 2002 2.0. Apparently this is a throttle position sensor fault but I'm not sure where exactly this is and would replacing it definitely solve the problem. I would appreciate any advice on what to do.
Martin
It will be on the end of the throttle cable, on the i-ctdi it is bolted close to the bulkhead.
Try good switch cleaner on the connector and leave for a day for it to penetrate inside.
Thanks for that, I will give it a go and see if that sorts it.
