The parcel shelf on my '51 Accord has got to the point where it doesn't lift up when the hatch is opened. Since I came to own it, the retracting string connector on the driver's side has been broken, as seen below:
The connector attaches onto a small plastic stud that's held in by a screw; on the side where the retractor is broken, this piece is missing. On the passenger side, the retracting string connector is not broken, but the plastic stud and the screw has been recently lost, and therefore the parcel shelf is no longer attached to anything, meaning it won't lift when the hatch is opened.
My question is thus: can the broken connector, as seen in the image above, be replaced with a new (or used) part? If it can, is it possible to source this part, as well as the two plastic studs/screws which the retracting connectors attach to, directly from Honda?
