Hi Fahad, sorry for the delay getting back to you. I've been down to the garage today and ran a few checks with the mechanic, his Snap On OBD reader came up with these readings:
It is showing P1384 Glowplug circuit fault. This has been checked and 1 glowplug is down.
Fuel pressure reqd = 60Mpa, Actual is constantly above this @ 69 to 73Mpa We also crimped the fuel rail over pressure valve pipe and no change. The injectors have all been leak back checked and sent to an injector specialist who said they were all within tolerance.
Voltage reading is 12.5v constant. This doesn't change when a booster set or running Transit is hooked up.
The car will start instantly with the tiniest sniff of ether and runs perfectly, no smoke or anything. Once the car is turned off it shows the crank pos sensor fault but this only shows after it has been running.
Getting back to the RPM readings: We cranked it over today (hooked up to booster) after it had been stood for a couple of days, there was no RPM showing on the OBD reader for 5 or 6 seconds, then it spiked at 83 and then zero for a few seconds then 140, same again then 117 and 109 and so on, (this is also backed up by the car's rev counter). Does this back up the crank sensor fault or is this normal? Does anyone know what the minimum starting RPM should be?
Thanks in advance lads.
