Other thing I want to ask, or maybe it's late to ask, as far as I see, mechanic didn't use any special cleaner for that. I saw him using WD40 in his hand. I think this is all he used. Do u think he might damage the Throttle Body?
It's mean you recommend to go for diagnostic?honda_saj said:I did say the low idle has nothing to do with water pump, I would suggest looking at mass air flow sensor or throttle sensor
It is 2.0 petrol K20Z2 engine.Jon_G said:Not sure if this version has a MAF or not (is it a 2.0 or a 2.4?) but this surging, erratic idle sounds to me like either an air leak on the intake side or the accelerator pedal position sensor (only on a 2.4, I believe?).
I have just checked the engine. Accelerator pedal is just a simple mechanism, connected by a metal wire to a black box in the engine bay, where I see an electric socket also connected to the same box. Which means sensor is inside that box.Jon_G said:On my diesel (and the 2.4, I believe) the accelerator pedal only connects to a box that contains a sensor (actually a pair of electrical potentiometers) to inform the ECU of the pedal position... this sensor is a not uncommon problem area. But I thought the 2.0 had a more conventional mechanical connection to a throttle butterfly?
But if your's is 'drive by wire' then the sensor should be considered to be a possible cause of your idle problem.
I did try everywhere after the throttle body with the spray.Jon_G said:Spraying a hydro-carbon 'fuel' into the engine like that would have caused the air-to-fuel ratio to plummet, probably below a viable level (according to the outcome). But I do say that without knowing what the carb cleaner actually contains.
Best to use switch cleaner on the APP sensor, as it's lubricating and probably a far more gentle solvent. WD40 would be OK, but you really need to get it inside the box and onto the wiping contacts within. Cleaning rarely seems to fix a failing APP sensor though...
Any chance there's an air leak on the intake side after the throttle body?
Agreed the most common is hairline crack in air flow pipe from box to throttle bodyRichard B said:Buy some carburetor cleaner and do a check for vacuum leaks on your engine.
There are Youtube vids that show you how to do it (Eric the car guy for example)
Minor vacuum leaks are quite common.
