So little update left the car in this morning expecting a smooth process few hours later some complications came to light because the recaro sits curved underneath where usually you bum sits this means if installed like that I won't be able to move the seats forward and back, next was that their was no way to use the rails on it either and not as simple as putting a bracket extension to make them fit, so I'm now goin to be getting a custom subframe made which will also bring the height up abit so the bottom doesn't touch also will be using the the oem accord rails modified to fit the recaros so should be all done in the next day or to, as for the airbags in the recaros I'm not going to bother with trying to see if they will work with the oem plug so I will be using 2.2ohm resistors for the seats in other words I won't have a airbag light on the dash plus the fronts will be still functional
