Replacement Discs and Pads options?
I will soon need pads all round and new rear discs.
Having had a quick scan thru ebay I reckon I can get all the pads and the 2 rear discs for £72 all in including postage
Discs are here: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290502637348&ssPageName=STRK:MEWAX:IT
Rear pads: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170394966720&ssPageName=STRK:MEWAX:IT
Front pads: http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170389037123&ssPageName=STRK:MEWAX:IT
Is there anything wrong with this kit? seems quite cheap!
cheers - phil
Seriously - does this stuff look ok? I guess it's all pattern stuff, but it should work ok shouldn't it?
Could be a bargain, but you can never tell the quality until after you have bought it...
Dunno if anyone here has bought from this seller in the past - but for that money it might be worth a punt.
Then again, do you want to be messing with cheap and nasty brake kits when that is all that stops you?
Tough one eh?
Seems too cheap to me. When normal pattern part front pads are about £30, it means the rest is only £40. Doesn't make sense to me.
As Dan says it's only thing that stops you.
I would never scrimp on safety critical parts.
