I made a temp blank for the egr and no change. this morning I have found a small split in the vacuum pipe going to the turbo actuator so iv changed that and manualy pumped some vacuum in to it and its moving the actuator but still no change iv exhausted all my thoughts now so I think it will have to go to Honda and be put on there machine like you suggest we did run a scan on it last night and nothing came up.F6HAD said:You need to run a diagnostic and look at live logging data to understand what's actually going on. You've eliminated the egr, my money is on the turbo.
See, that's how useless Honda dealers can be... sounds like he didn't even consider running HDS interactive test routines which would have shown up which sub-system was failing, but simply offered a simple OBD2 scan to look for stored codes? Waste of time!piglet1 said:I went to Honda this morning to collect the seal and they have informed me the live data will probably not show anything up if its not putting any codes up and the boost pressure valves are working anyway so I'm stuck again the chap has offered me a replacement turbo so looks like I need to swop them over again
As Saj says, HDS or equivalent (interactive, target-setting) diagnostics would be ideal. I suggest you at least speak to the Bosch Service Centre at Church Stretton to see what they can offer.piglet1 said:Ok so I need a HDS test ?
Well that's disappointing too! Makes you wonder what is the point of specialists...piglet1 said:iv just spoke to a Bosch service centre and explained whats happening they have advised me again without any management lights coming on its very unsightly they could pick anything up
Iv explained the situation to 3 separate garages one Honda one Bosch and one independent and asked for a live data diagnostic and all 3 have said if its not putting the engine management light on or throwing up any codes its very unlightly the diagnostic will show anything upJon_G said:Well that's disappointing too! Makes you wonder what is the point of specialists...
This is nonsense. I don't own an HDS, but I have borrowed one from member Freddofrog (who is currently on holiday) to extensively run tests on my engine... it enables targets to be set (so, for example on the diesel, fuel pressure, turbo boost, EGR %, IMRC position) and then monitors how accurately that engine sub-system achieves the set target... mine failed on fuel pressure, despite no previous error codes in this regard.piglet1 said:Iv explained the situation to 3 separate garages one Honda one Bosch and one independent and asked for a live data diagnostic and all 3 have said if its not putting the engine management light on or throwing up any codes its very unlightly the diagnostic will show anything up
Jon I believe you and don't get me wrong I'm grateful for any and all advice and I'm trying things as I'm recommended them its just the 3 garages I spoke to didn't think it would work and there for didn't want to do itJon_G said:This is nonsense. I don't own an HDS, but I have borrowed one from member Freddofrog (who is currently on holiday) to extensively run tests on my engine... it enables targets to be set (so, for example on the diesel, fuel pressure, turbo boost, EGR %, IMRC position) and then monitors how accurately that engine sub-system achieves the set target... mine failed on fuel pressure, despite no previous error codes in this regard.
I'm not making this up, I've actually done it and have previously posted pictures on the forum. It can also log in real-time engine performance against ECU-generated targets as you drive around.
I know that Fahad has his own HDS (which he uses regularly in connection with his work) and can back me up on this.
its connected and working I did wonder if the pumps where the same but Jon had a look for me and they both have the same part number so are the samewoodie said:is vacuum pump on FL engine compatible with PFL controls ?
is the vacuum pump connected up and working ?
is there any way of testing the fsvF6HAD said:It sounds like none of them can be bothered getting involved. Any decent mechanic will be able to get to the bottom of it mate, it's going to be either an intake or boost problem. If not the egr then possibly the intake flap.
Hopefully you used your original FSV?piglet1 said:is there any way of testing the fsv
He has his own HDS and can obviously advise you on diagnostics, etc as well.piglet1 said:...as far as contacting Goodluckmonkey no I didn't but iv just messaged him now
No rags in the intake pipework then?piglet1 said:right todays update absolutely sweet F A live data apparently didn't show up anything out of the ordinary the imdc is moving so I'm ***uming the fav is working ok and yes its my original one
I just had a random thought that the rag I put in the exhaust when I was degreasing the engine bay may have not totally been removed and was suffocating it when you rev the car but iv removed the exhaust and still no change that would have been far to simple
