Upgrading Front Door Speakers
No, air "vibrates" at a frequency (or spectra of frequencues). If you take one frequency, it's easier to explain.
A vibrating guitar string vibrates "transversely" which means that the vibration is at right-angles to the direction of the energy travel (and light is a transverse wave as well).
However sound is a "longitudinal" wave, which is actually easier to consider, because the vibration is in the same direction as the energy travel. In effect, for a single frequency set up as a "standing wave", the vibration constists of air at slightly higher densities and slightly lower densities spread out in the air space, with one higher density and one lower density region in the wavelength of the frequency.
This is what you will get from one loudspeaker. If you place another loudspeaker next to it, then if it is wired in anti-phase, the lower density regions over lap with the higher density regions from the other speaker, and vice versa, so they cancel one another out. Obviously the two centres of excitation are not at the same point, so they cannot totally cancel out.
As you move the speakers further apart, the cancellation pattern starts to change, depending on the resonance of the air space. Two speakers wired anti-phase opposite one another in car doors, will produce a very different pattern of vibration in comparison to when wired in-phase. In-phase will basically resonate the air-space more efficiently than anti-phase.
I'm with you there, that does make sense and to be honest you probably would notice a difference in the case of speakers being out of phase.
I was talking about both being inverted didn't think about out of phase set-up- doh me!
^ yeah as long as they're both (all) wired the same way around, it doesn't matter which way
here they are still confused which is positive or negative, experts please :) help me
http://www.flickr.com/photos/13812399@N00/8491448805/
Right door, purple/white and grey
http://www.flickr.com/photos/13812399@N00/8491450975/
left door, red/white, purple
It's difficult to say from those pictures.
Which ones are from the wiring loom and what are the colours ?
Sorry for the previous poor quality picture, here's a better one
For driver's side
http://www.flickr.com/photos/13812399@N00/8531011504/in/photostream/
For passenger's side
http://www.flickr.com/photos/13812399@N00/8531012490/in/photostream/
Thanks in advance
looks like purple/white may be the common colour on both sides, which suggests it's the "ground" (not to be confused with the chassis ground) so connect these to the "-" or "neg" on the speakers each side.
Just asked my trusty Honda mechanic, he told me that those grey coloured wire are usually negative and the brighter coloured wire are positive ( as a general rule of thumb!)
here you go :)
