freddofrog
won 16.4k on Euro lottery :)
I think you're right about the "back-fire" theory because to remove the tensioner, you compress it by turning the crankshaft backwards.Channel Hopper said:I disagree. If the engine has been turned over after the first problem arose then you cannot do any further damage (unless the chain moves over more teeth). If there is no damage but the timing is out, then the cylinders should be showing roughly the same compression since the timing is the same on all, though the full number - 135 psi ? - will not be reached.
If one or more is significantly different to another then you know you need to take the head off.
It's on the side between crankshaft-sprocket and exhaust-sprocket, see images
So if the engine runs backwards, the tensioner stops working, and the chain will jump past the inlet-sprocket. Nasty h34r:
But I think that Miah wants to reset the inlet-sprocket because there is the possibility that the valves are ok and you need the valve-timing correct to get max compression ?
