H Peasource
Injector King
Can't give you a definite answer but I agree with your understanding of how most common rail pumps regulate pressure. The valve is very likely to be part of the pump.
That said I suspect that the valve itself is not your problem. It's far more likely to be a problem with the wiring. In your position I'd be checking the wiring carefully for any chafing/breaks, checking for any loose pins/sockets and tightening them up and then cleaning everything with a good contact cleaner followed by some silicon contact lubricant.
Alan
Alan
