Hi guys, my first post. I have a 2005 2.2i-cdti sport with 145000 on the clock and I've had it since new and its been a gem. Until last Saturday she had never left me by the side of the road, only drive shafts and the exhaust manifold have been changed since new. It started to take longer to start and within a few days I finally couldn't start her, called the RAC, decided to buy a new battery (the original one failed on their tester) and she started after a long crank. The new battery was only a temporary remedy, and pretty soon I resorted to the Easy Start, which is now the only way i can get her going. Just to point out, she runs absolutely fine once going, no flat spots, plenty of power etc. I changed the fuel filter as a precaution (still 5k to go on the old one) but no joy. Did a leak back test on the injectors and had one which was 25% over the others while idling (it took a few minutes to fill the bottle). Ordered up a reconditioned injector from GAP-Injectors and got my local Bosch service centre to fit and they found it to be duff (she still ran on three cylinders) so replaced the old one. I'll send the injector back. However, on their own leak back test they didn't think the rate of leak back would effect the common rail pressure enough to effect starting 'my injectors are fine'. Just to make sure the RAC battery was not the problem, I tried starting with a another (running) car's battery connected on jump leads - no difference. So -
Is it the starter motor - what crank rate should I expect? I get about 200 rpm according to the rev counter, and if I get anything above that she starts.
Is it the fuel pump - dread the cost of that- how do I check
Is it the injector - it leaks back but not signicantly
Any ideas of further tests I can run myself?
