No can be done with everything intactCliffordski said:Do you not have to drop the subframe to do the fronts?
AndyHK said:Easy DIY, only need to undo a couple of nuts/bolts, remove the bracket, replace the bushes.........
I just bought 4 bushes for the front and rear of my saloon from the nearest Honda and cost £20, bargain!
Yes, I had to.Cliffordski said:Do you not have to drop the subframe to do the fronts?
Really? How did do get at the rear bolt on the ARB holder? This is buried between the subframe and the car body. I had to drop the rear of the sub-frame slightly to get at it.TypeR said:No can be done with everything intact
I actually had this problem and ever since i did my upper control arms it went away
