Jump to content
ABS & VSA Fault, anybody got any advice?... please, cos I wanna scream
  • Please log in to reply
37 replies to this topic
#1 hikeifulike
hikeifulike
  • Members
  • PipPip
  • 46 posts
  • Name:Gary Porter
  • Car :04 Honda Accord 2.4
  • LocationSwindon
Posted 28 April 2017 - 01:49 PM
Update...
Right then, where do I start...
Decided to clean under the wheel arch, only to find that a bit of the arch collapsed due to rust, and possible damaged the rear wheel speed sensor after cleaning out the years of gunk.
VSA & ABS lights came on.
Had a diagnostics, and got a new sensor, Halfords, £173 fitted, as apposed to Honda's £160 just for the part.
Picked the car up and the Warning triangle came on, then the VSA light, grrrrrrrrrr... back to Halfords, did a new diagnostics and now they tell me something about ”Sensor Logic Failure” AAAARRRCCCHHHHHHHHHH
:angry: I SHOULD HAVE NEVER CLEANED THE WHEEL ARCH. :angry:
oh and they cant do anything about it as the are not auto electricians.
I only wanted to clean the arch and now its body work, spray painting and electrics..... Im starting to think, I should push it into the river.
 Ok not really, I love the car, but OMG. :(
#2 Goodluckmonkey
Goodluckmonkey
    Advanced Member
  • TA Friends
  • PipPipPip
  • 1,618 posts
  • Name:Matt
  • Car :CN2
  • LocationKent
Posted 28 April 2017 - 01:53 PM
Sounds like Halfords should be giving you a full refund.
Has the ABS light gone out?
  • Jon_G likes this
-35mm Apex Springs
#3 honda_saj
honda_saj
    Advanced Member
  • Members
  • PipPipPip
  • 1,154 posts
  • Name:sajeel
  • Car :honda accord
  • Locationlondon
Posted 28 April 2017 - 03:26 PM
Is your petrol model ?
Regards,
saj
#4 freddofrog
freddofrog
    won 16.4k on Euro lottery :)
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
  • LocationOff abroad
Posted 28 April 2017 - 03:58 PM
04 Honda Accord 2.4  ...under the OPs avatar
Update...
any idea what they used for the initial diagnostics  ?
and I definitely don't understand the "auto electricians" thing, the codes should indicate the issue
edit:
and I have a Honda HDS and live 50 miles west of Peterborough if that helps ;)
Edited by freddofrog, 28 April 2017 - 04:02 PM.
  • Cliffordski and hikeifulike like this
#5 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 989 posts
  • Name:Stephen
  • Car :Accord 7 Estate 2005
  • LocationKT8 Postcode
Posted 28 April 2017 - 04:36 PM
If it wasn't the only wheel arch you cleaned it could be one of the other sensors (or all four.............................)
#6 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • Car :Honda Accord CN1
  • LocationSlovenia
Posted 28 April 2017 - 07:19 PM
This is a bit strange.
I changed time ago all 4 speed/ABS/VSA sensors and there was any fault after change
Poslano z mojega SM-N910C z uporabo Tapatalk
#7 hikeifulike
hikeifulike
  • Members
  • PipPip
  • 46 posts
  • Name:Gary Porter
  • LocationSwindon
Posted 29 April 2017 - 05:53 AM
Hi everyone, it's a petrol. I only checked the right rear wheel, so no others should be at risk... Fingers crossed.
As I'm not working yet, (recently relocated to Peterbrough, but promise of a job on the horison), I'm holding back, I have decided that when I am earning again, I will take my baby to Honda, for a complete check and to hell with the cost. I have also approached a body shop for a quote on checking the wheel arches and repairing and spraying them and other minor marks.
The guy at Halfords did mention there was other faults and I got the impression he wasn't too confident with what he was doing as he kept seeking advise, and as they charge £49 to diagnose, I insisted they check again, but they said I need a auto electrician.
So I am gonna wait for now, till I have some cash coming in.
#8 hikeifulike
hikeifulike
  • Members
  • PipPip
  • 46 posts
  • Name:Gary Porter
  • LocationSwindon
Posted 29 April 2017 - 05:54 AM
edit:
#9 hikeifulike
hikeifulike
  • Members
  • PipPip
  • 46 posts
  • Name:Gary Porter
  • LocationSwindon
Posted 29 April 2017 - 05:59 AM
Hi
It was a friend of a friend that did the initial check for me, as he was doing it as a favour for a tenner, and he came up with the first fault, which led me to taking the car for the new sensor, I knew this would be accurate as I was messing with the rear wheel area cleaning out years of road muck, and I was quite rough. After the new sensor, Halfords only checked again, as I went back to them like I mentioned, but then they said they couldn't help anymore.... But I'm thinking I should insist on another mechanic.
If I don't manage, I might just take you up on your offer, I'll let you know.
Cheers for the support.
#10 Andyjdmteg
Andyjdmteg
    Advanced Member
  • Members
  • PipPipPip
  • 590 posts
  • Name:Andy Collins
  • Car :Accord Type S
  • LocationHitchin
Posted 29 April 2017 - 06:59 AM
Sensor logic failure means the vsa reset procedure needs to be done, either with a Honda hds (or compatible) scanner or the "paper clip method" which is documented on here.
Your probably getting the 84-01 error code. I've used the paper clip method and can tell you it works as long as you clear the abs code first (also with the clip)
I've also used Honda to do it before I realised it can be done by myself.
Edit - you don't have to use a paper clip any suitable gauge of wire will do
Edited by Andyjdmteg, 29 April 2017 - 07:02 AM.
  • Jon_G, Cliffordski and hikeifulike like this
#11 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
  • Car :2005 Tourer i-CTDi
Posted 29 April 2017 - 07:28 AM
Vehicle diagnostics is only as good as the person doing it (and that goes for Honda as much as Halfords)... as already mentioned, our cars have built-in diagnostics that can be initiated by shorting certain pins on the diagnostics port (4 & 9) and simply watching a light flash. It really can be that simple but, importantly, it's how the technician fully interprets the reported problem that really is the key thing.
However you'd be far better off taking up Freddofrog's offer... he has his own Honda Diagnostic System, the official Honda workshop manual and a lot of experience with his Accord (I've even let him run diagnostics on my diesel!).
  • toffee_pie and hikeifulike like this
#12 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 29 April 2017 - 08:10 AM
Can u please explain how can you reu VSA reset procedure?
#13 freddofrog
freddofrog
  • Banned
  • PipPipPip
  • 7,326 posts
  • Name:.Freddo
  • Car :TBD
Posted 29 April 2017 - 09:13 AM
here is his method  http://typeaccord.co...d-vsa/?p=237953
might be worth a try by the OP ?
and #6 #7 #9 here on how to read the codes http://typeaccord.co...trick/?p=165713
Edited by freddofrog, 29 April 2017 - 09:19 AM.
#14 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 29 April 2017 - 09:17 AM
#15 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 29 April 2017 - 03:06 PM
Does Acura/Honda USDM and EUDM have the same OBD2 port?
#16 Jon_G
Jon_G
    No Longer Active
  • Banned
  • PipPipPip
  • 5,124 posts
  • Name:Jon
Posted 29 April 2017 - 03:39 PM
I'm not familiar with US variants, but the OBD port shown/highlighted in that YT clip looks exactly the same as my UK model.
#17 Andyjdmteg
Andyjdmteg
    Advanced Member
  • Members
  • PipPipPip
  • 590 posts
  • Name:Andy Collins
  • LocationHitchin
Posted 29 April 2017 - 06:20 PM
If your after the port numbers look closely at the diag port with a torch, you can just make out the numbers for each pin
  • freddofrog likes this
#18 Channel Hopper
Channel Hopper
    Advanced Member
  • Members
  • PipPipPip
  • 989 posts
  • Name:Stephen
Posted 29 April 2017 - 06:51 PM
OBD is a worldwide standard so the pin numbers will be the same.
Many of the videos confirming the dashboard flashes for ABS are from the US (or show LHD vehicles) so I would suggest wherever the car is, the plug in diagnostic is the same.
#19 Jan Accord
Jan Accord
    Advanced Member
  • Members
  • PipPipPip
  • 539 posts
  • Name:Jan
  • LocationSlovenia
Posted 30 April 2017 - 12:14 AM
^^thas exactly what i want to know.
I just asked in the wrong way [emoji53]
The pin position in the port should be the same
Edited by Jan Accord, 30 April 2017 - 12:35 AM.
#20 Cliffordski
Cliffordski
    And still...
  • TA Friends
  • PipPipPip
  • 1,467 posts
  • Name:Cliff
  • Car :13 Tourer 2.4 EX man
  • LocationCounty Durham
Posted 30 April 2017 - 08:33 AM
+1 why not pursue this with Halfords head office first of all.
