Jump to content
Wheel Alignment, balancing, runout....
  • Please log in to reply
18 replies to this topic
#1 Alnug
Alnug
    Creator / Admin
  • Administrators
  • 1,017 posts
  • Name:Alan
  • Car :2.4 Type-S
  • LocationWakefield
Posted 08 August 2010 - 02:59 AM
This is gonna be long, so bear with me! it may seem over the past few months my contribution to the forum has reduced...that's because I've been having a bad problem with the car :-(....READ ON!
THE SAGA BEGINS!
IN december I had my wheels replaced due to corrosion of the alloys..very minimal but the dealer did it anyway and mounted my old tyres onto them. since then i've been having dreaded vibration problems at around 65-75mph....i thought..it's just the wear pattern on the tyres and the two front tyres almost needed replacing so i left it another 1000miles when i bought some new tyres to replace the fronts...vibration still there so i got them rebalanced hoping this was it....it didn't work!
Fine i thought i'll swap the wheels around...vibration still there but slightly different!.....now i was getting annoyed.
I finally resorted to booking it back into the dealer to check..again very helpful and they told me the tyres are out of balance. i thought fine...ENOUGH of this balancing, it been balanced twice before (three times including the original balance by the dealer when they replaced the alloys!).
BALANCING
I had enough of balancing issues and located a Hunter GSP9700 road force machine - in derby! (I'm in leeds) got them to redo the balancing and checking for runout and apparently they were fine (OR SO I THOUGHT!!!! read later). I also had them check alignment on their 4 wheel alignment machine and they adjusted it.
On my drive home..initially thought was ok but the vibes were still there although reduced somewhat, these were NOT steering feel from the road..they were vibrations which wobbled the wheel.
I got to the stage, questioning myself whether the car was like this all along but i really couldn't believe it was like this......you know what it's like after a while you begin to question yourself!!!
I thought i had ruled out balancing as a cause (SO I THOUGHT!) and was now thinking more about suspension, driveline, bushings and ball-joints....as you would have guessed at this stage i was quite depressed....i had babied the car and can't believe there is now this thing which is spoiling the experience!!!!!!
It was back to the dealer again to look deeper into the driveline, steering an suspension. On the ramp I was called in and the dealer said that the alignment looks off and said the suspension bits are all tight.....But I just had it done!!...dealer was very good about this and didn't charge me for their time (Very good dealer Stratstone Honda Leeds).
I was sooo depressed!! and i was beginning to think that maybe there was a fault with the tyres I bought. A long shot I know but i really didn't know what it could be.....CV joint hub etc were floating in my
head....and so were ££££££££££££££££££££££££££££££££££££££££££.
I made a radical decision........I'm gonna get some new alloys with some tyres!!!! since I wanted to change the alloys anyway.
THE NEW ALLOYS + brakes
Well a week later I had my new alloys (make and model will be posted later :-)) and some yokohama tyres.
I STILL GOT BLOODY VIBES!!!! but much more reduced I couldn't bloody believe it! I was about to really give up on the car..but i perservered, i knew it was a better car than this! I turned to the front brakes after much googling.....looked at my brake discs and yes they were at the limit...i changed them, doing a maticulous job of cleaning the hub before getting the new discs on and also checking for runout.
New Discs and new pads later......still there!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I didn't know what to do.....I really didn't! the car actually seemed to be getting worse! it felt like it was wandering and didn't feel as sharp as I once remembered.....but at this point i thought this was how the car always drove! Somehow I felt the alignment just didn't feel right, even though I'd just had it 4 wheel aligned with printout!
I frantically searched the web again and found a place called The wheel alignment and ball joint centre www.4wheelalignment.co.uk, located in liverpool...who seemed to have solved a lot of problems that others
couldn't. I made an appointment and went......
ALIGNMENT AND BALANCING AGAIN!!!!!!!!!!!!!!
Well i got there and thought since I'm here I asked them to see if the wheels were balanced. They checked it using a fine balance mode on the balancer and sure enough they were out of balance....but to be honest nothing surprised me anymore.......i resorted to thinking EVERY BLOODY SHOP IS GONNA GIVE ME A DIFFERENT BALaNCE! Anyway all 4 wheels balanced and up on the alignment ramp.
THE SHOCK!
The car was really far out of alignment!!!!!!!!!!!! Apparently the rear adjustment nuts were not tight...in fact they were loose!!! You see my car has Ingalls rear camber adjustment kit and the nuts where not tighten...as in they forgot!!!
in a 4 wheel alignment, the rear tyres are aligned straight and the front wheels are then matched to the rears. I guess the rears had been slowly wiggling out of alignment giving me that strange feeeling.
Anyway I MADE SURE that all the nuts were tightened properly this time!!!!
I thanked them and left thinking..here i go again...i didn't expect anything....on pulling off yes the car felt much more connected to the road seemingly, but i was still in the middle of liverpool so couldn't tell.
THE RESULT!
well I got onto the motorway, the car felt so much more like how i remembered it to be! but there was still a slight shimmy although it was very slight now......i drove home thinking well at least it's not wandering anymore and feels tight. drove 30 miles and i thought to myself, there is much less vibs, drove another 30miles and the vibes seemed to turn into road feel.......i couldn't believe it.
I stopped at a service station to get gas, thinking that the vibes will just return when i get back to motorway speeds. Back on the motorway and no it was just road feel!!!!!!!!
SO THIS IS HOW THE CAR FEELS I THOUGHT! I remembered why i loved the car sooooo much!!
================THE ANALYSIS====================So my car had finally been cured! what a case of baddddd luck to have the alignment and balance of the new alloys out!!!!
I needed to find out what the hell caused all this! 3 months had now passed for me to find a fix! i took it on myself to look again at the original alloys replaced by the dealer. I spun them one at a time on one of the front hubs of the car and found 1 to have a lateral runout of 1.8mm!!!!!!!
YOu could see it wobbling left to right when looking down on the fender! I couldn't believe this even after having them on the famed Hunter road force machine!!!!!!
Why did the HUNTER GSP9700 balancer miss this?
Here is what i think. to measure runout on the rim the operator attached two measuring arms to the inner and outer lips of the alloy..in effect i think the machine measures lateral and radial runout by measuring the difference between the two arms....yes it will detect a defect if there is a big dent in one side but in my case it was as if the alloy wheel was twisted at the hub section....so effectively the inner and outer edge of the alloy still measures as parallel!!!!!!!!!!!!!!
THIS IS A HUGE FLAW IN THIS MACHINE!.....sure it balances fine but i think the runout measurement is not all too good!!! As you can see from my case!
===============THE CONCLUSION================
I had my old alloy wheels balanced 3 times in total...no-one caught this lateral runout..... not even a so called top the range road force machine......it took a guy who was determined and spent a lot of time and sweat to find the problem that others just kept saying.....
''''''''''''''Oh it's a characteristic!!!!!!'''''''''''''''''''''''
It took a guy who knew his car and perservered to find a problem that was missed by the most sophisticated machines and so called professionals!
============ The LAST WORD =================
KNOW YOUR CAR! 3 months and I think there's not a single bit of the suspension or steering that I'm not intimate with. I think I have the most finely aligned/ riding Type-S in the whole of UK, here is the alignment specs, before and after alignment at liverpool, feel free to match it if you want to feel how the car should feel!
Posted Image
.....This is more of a note to myself to say
THE CAR drives as well as you remember it..there is absolutely no vibration, but road feel, don't ever doubt it again!! it's a fantastically handing and riding car!
I hope you found this useful!
- The feel of something that you thought you'd lost is priceless!!!!
A machine is only as good as the operator using it!
New site MUGEN ACCORD
If you like how TypeAccord looks and appreciate my help and effort Posted Image !
#2 dinoc
dinoc
    Advanced Member
  • Members
  • PipPipPip
  • 383 posts
  • Name:Dinu
  • Car :2008 Accord Type-S
  • LocationBucharest
Posted 26 August 2010 - 11:47 AM
Hi Alnug,
I see the alignment you've obtained here was with Ingalls rear camber kit, but was it with stock suspension or lowered suspension ?
Something else, can you modify the caster ? I'm wondering how the car will feel with a bigger caster (on the green range of course).
Edited by dinoc, 26 August 2010 - 11:52 AM.
'07 Accord CL9 Type-S with Navi: ECU reflashed, Weapon-R headers, Comptech Icebox, J35 TB, Hondata + P2R IM gaskets,
4.7 Final Drive, Wavetrac LSD, Honda Sport Suspension, H&R Front and Rear anti-roll bars, Alutec strutbar,
Mugen Quick Shift, JDM Type-S front grille, Buddy Club condenser, reverse camera, Grom Audio
#3 dinoc
dinoc
    Advanced Member
  • Members
  • PipPipPip
  • 383 posts
  • Name:Dinu
  • LocationBucharest
Posted 28 August 2010 - 06:40 AM
Alnug did you have your Ingalls (at the time you made this alignment) with your stock suspension or lowered suspension ?
#4 Alnug
Alnug
    Creator / Admin
  • Administrators
  • 1,017 posts
  • Name:Alan
  • Car :2.4 Type-S
  • LocationWakefield
Posted 29 August 2010 - 10:31 AM
hi yes it had the ingalls on...otherwise you won't have camber readings like that :lol:
It was with lowered suspension and no you can't adjust caster on the Accord due to suspension set-up...anymore B)
#5 dinoc
dinoc
    Advanced Member
  • Members
  • PipPipPip
  • 383 posts
  • Name:Dinu
  • LocationBucharest
Posted 29 August 2010 - 10:35 AM
Thanks Alnug!
#6 dinoc
dinoc
    Advanced Member
  • Members
  • PipPipPip
  • 383 posts
  • Name:Dinu
  • LocationBucharest
Posted 29 August 2010 - 07:15 PM
Alnug I have stock suspension but upgraded anti-roll bars front and rear + a strong front strutbar the car feels much better now , the body-roll is reduced and it handles betters.
But I believe it needs a better alignement, so as I have an Ingalls kit sitting around unused from my previous CL7, do you think it will worth trying to have a negative camber on the rear (like -1 degree) each side, with my setup ?
As I've understood there is nothing I can do about front camber (without an aftermarket kit) , caster , so it remains to get toe to zero front and rear and maybe a negative camber on the rear ,,, what do you think ,
will it worth doing it with my setup ?
Edited by dinoc, 29 August 2010 - 07:19 PM.
#7 Alnug
Alnug
    Creator / Admin
  • Administrators
  • 1,017 posts
  • Name:Alan
  • Car :2.4 Type-S
  • LocationWakefield
Posted 29 August 2010 - 11:35 PM
Dinu, I can't recommend you anything unless you can give me your stock readings as they are now, adjussting rear camber has the effect of making the car turn more sharply in cornering, however you slightly affect stright line on centre stability...this is more noticeable when you have stiffer suspension. Your best bet really is to try different camber settings at the rear, as to how you like it,..but you should start with the stock settings and tune it from there...for what it's worth I'm at -0.5deg each at the rear.
#8 Jon2.2
Jon2.2
    Advanced Member
  • Members
  • PipPipPip
  • 158 posts
  • Name:Jon
  • Car :honda accord i-ctdi
  • Locationliverpool
Posted 28 October 2010 - 12:04 PM
I took mine to that place in liverpool as i live 10 mins away, very good workshop and helpful people, my readings are slightly different as the guy found that my rear springs had sagged :| and also i have 4 different makes of tyres, he looked offended that i had 4 different types! lol but im getting all new tyres and rear springs and going in for another alignment free of charge
#9 birdy
birdy
    Newbie
  • Pre-Members
  • Pip
  • 12 posts
  • Name:Neil Burdess
  • Car :Honda Accord ctdi
  • LocationManchester
Posted 31 October 2010 - 06:13 PM
Think I need mine doing, car pulls to the left and a slight wobble has just appeared. Tyres are all new and balanced.
Going to book it in at a place in Bolton next week (Nigel .......?)
How much are we looking at for the alignment?
Thanks Neil
#10 Monks
Monks
    Admin / Co-Founder
  • Ex Admin
  • PipPipPip
  • 3,054 posts
  • Name:-
  • Car :-
  • Location-
Posted 31 October 2010 - 06:29 PM
Neil its best to get proper four wheel check on a hunter system, see this link for the nearest machine near you http://www.alignmycar.co.uk/
Price wise it ranges from £50-£70
#11 birdy
birdy
    Newbie
  • Pre-Members
  • Pip
  • 12 posts
  • Name:Neil Burdess
Posted 02 November 2010 - 08:38 AM
Cheers, Just done a search and Nigel Langs in Bolton is on the list :-)
#12 Max10
Max10
  • Members
  • PipPip
  • 36 posts
  • Name:Mo
  • Car :Honda Accord Diesel
  • LocationCoventry
Posted 13 March 2011 - 10:53 PM
I have just bought Honda accord diesel and I am certain car is pushing to left. The bloke i brought the car off has recently changed the rear tyres but did not notice anything. I live in Coventry, can anyone recommend something,.. Shall I balance and track all 4 wheels.
#13 Michael
Michael
    Advanced Member
  • Members
  • PipPipPip
  • 179 posts
  • Name:Michael
  • Car :2.2 CTDi EX
  • LocationDevon
Posted 14 March 2011 - 05:32 PM
Pulling to one side is far more likely to be your tracking/alignment/geo (whatever you want to call it). Generally incorrect Camber or Toe on the front or rear suspension. Go to somewhere that does alignment and get them to check it out first.
Stage 3 Hybrid Turbo Install Underway:  http://typeaccord.co...-turbo-install/
Aim: 220+ hp - we'll see :)
#14 Max10
Max10
  • Members
  • PipPip
  • 36 posts
  • Name:Mo
  • LocationCoventry
Posted 14 March 2011 - 06:34 PM
Got the tracking down as the mechanic said front right was a liitle off so could be reason why call pulling to left. Car seems lot better. Is getting the alingment done same as the tracking?
#15 MOHAMMED FAS
MOHAMMED FAS
  • Members
  • PipPip
  • 23 posts
  • Name:MOHAMMED
  • Car :HONDA ACCORD TYPE R
  • LocationREADING, BERKSHIRE
Posted 05 July 2011 - 03:12 AM
On my 2001 accord the back wheels are slight in from the top and one of the tyres is wearing out. Have no idea whats causing this but it is stressing me out . Could you help?
Edited by Alnug, 05 July 2011 - 04:26 PM.
i just edited the post to remove the HUGE quote lol
#16 Alnug
Alnug
    Creator / Admin
  • Administrators
  • 1,017 posts
  • Name:Alan
  • Car :2.4 Type-S
  • LocationWakefield
Posted 05 July 2011 - 04:28 PM
it sounds like you have the rear camber issue (have a search on here) it is basically that the upper control arm is causing the tyres to wear the inside. but before jumping to conclusions....
It all depends what you are at now...you need to get it to a centre that can give you a 4 wheel alignment printout as a starting point...also do you have modified suspension? lowered etc?
It maybe just a case of the alignment being out...
#17 MOHAMMED FAS
MOHAMMED FAS
  • Members
  • PipPip
  • 23 posts
  • Name:MOHAMMED
Posted 08 July 2011 - 03:20 AM
CHEERS MATE. TAKING IT IN NEXT WEEK TO GET IT DONE STRAIGHT HOPEFULLY. BUT I NEED TO FIND OUT IS WHAT IS THE CENTRE READINGS, IF ANY ONE CAN HELP ITS A 2001 ATR. ALSO ITS ON THE STANDERD SUSPENSION.
#18 Dan Robinson
Dan Robinson
    Grand High Plumber
  • TA Friends
  • PipPipPip
  • 9,601 posts
  • Name:Dan Robinson
  • Car :06 EX Tourer i-CTDI
  • LocationHenlow, Beds
Posted 08 July 2011 - 06:57 AM
Dude, keep the caps lock off please, it makes your post hard to read (and is the web equivalent if shouting). Cheers :D
<!-- isHtml:1 --><!-- isHtml:1 --><p class='bbc_center'>06 (facelift) Tourer EX Graphite w/ Pentas, Stage 1 Remap by <a class='bbc_url' href='http://www.premiertuning.com/'>Premier Tuning</a>. Nice. With a genuine fake real spoiler. Factory fit. Probably the best spoiler ever. A-Spec suspension - makes the world a better place.</p><p class='bbc_center'><br /><img src='http://lh5.ggpht.com...8 - shopped.jpg' alt='Posted Image' class='bbc_img' /><br />It's a constant race between making things idiot-proof, and the universe making better idiots.<br /><br /><span style='font-size: 10px;'><a class='bbc_url' href='http://typeaccord.co.uk/forum/topic/4073-ta-shirts/page__st__160'><span style='color: #FF0000'>Get your TA Shirts here. While stocks last.</span></a></span></p>
#19 nduli
nduli
  • Members
  • PipPip
  • 70 posts
  • Name:richard
  • Car :CDTI exec saloon
  • Locationlancs
Posted 01 August 2011 - 09:09 PM
birdy - how did you find langs they are my local and may need to make a trip there soon? how much did they charge you?
