Mine is also a Chinese clone.
AFAIK, all HDS for 7th gen connect to the PC/laptop via RS232.
RS232 uses a 9-way D-type the same size as a VGA connector (except the opposite "***").
I had an older PC in my loft with RS232 built-in to the motherboard, and I tested the HDS on that to begin with (because I had full control over the RS232 COM Port settings in BIOS).
When I got it working on that PC, I then had two options for a modern laptop
1. an RS232 adapter on a PCMCIA card. This is a small card that plugs into the PCMCIA slot on a laptop with a 9-way D-type on the card. I bought this item on ebay from a UK supplier for about £10. The driver disc that came with the item was ok, but the COM Port settings were "hard-wired" on the PCMCIA card, and were incompatible with the COM Port settings in the HDS software (no way to change the settings in the HDS software). So I contacted the seller, explained the issue, sent it back, got my £10 back.
2. an RS232 adapter on a USB cable, which plugs into any USB slot, which has a 9-way D-type on one end (with a lump in the cable for the hardware converter). I bought this item on ebay from a Chinese supplier for about £3. I had a lot of trouble with the tiny driver disc that came with this item. I messaged the chinese bods that sent it to me, and they were extremely helpful, giving me various links on the internet for drivers. Eventually I found drivers that worked, and then I had to set up the COM Port settings in Device Manager same as I had set them up in BIOS on the older PC. It worked !!
Basically, the RS232 settings in the HDS will only work with certain RS232 COM Port settings (either real or virtual), but once it is set up properly, it has no problems. USB has a superior bit-rate to RS232, so there is no bottle-neck. How the HDS software finds the data inside the laptop, from a "virtual" COM Port is a mystery to me, but it does find it..
Also, I think that the USB-to-RS232 cable will only work on a built-in USB connector on the laptop, it won't work through an external USB Hub, so if you only have two USB sockets on the laptop, you must plug the USB-to-RS232 cable directly into one of the sockets, and use a Hub on the other socket (if you still require two other USB devices).
To summarise
1. HDS comes with an RS232 cable to connect to the PC/laptop
2. If you do not have RS232 hardware on your PC/laptop, use a USB-to-RS232 converter cable
3. The USB-to-RS232 cable must plug directly into a USB slot on the PC/laptop
4. You must have the right drivers for the converter on the USB-to-RS232 cable
5. You must be able to have full control of the RS232 COM Port settings in Device Manager
