Clutch pedal possible leak
marculos2
Leicester
Honda Accord 2.4
I was cleaning the inside of the motor today and I noticed a possible small leak under the clutch pedal and it looks like some grease on the clutch pedal piston, could this be a leaky cylinder, appreciate your thoughts.
looks like the father in law had greased/lubed the clutch pedal piston and looks like no clutch fluid is leaking so guess cylinder is ok.
There is a post about the clicking noise from the clutch master cylinder. Honda has upgraded master cylinder.
Sent from my SM-G901F using Tapatalk
