I totally agree with Paul and Fahad, the DPF may well have hardened ash that will not come out now.
But it would be worth trying a run in the car at the correct speeds to see if it can clear it itself. My son has a Seat Leon TDI FR, and he mostly does
very short journeys in it, so the DPF light comes on regularly. Despite me going through the conditions required, he still cannot clear the DPF warning light in his car as quickly as I can. Example from several weeks ago: 2.5 miles from my house there is a dual carriageway that is 1.5 miles long, and he told me that when the light comes on he drives up and down the dual carriageway several times to clear it. I told him to let me know next time, and I would drive the car, with him in the passenger seat, so that he could see what I was doing. I drove with the engine at 1400 rpm as much as possible (30 to 40 mph in relevant gears before the dual carriageway, then continued at 40 mph along the dual carriageway). The light went out just after the end of the first run up the dual carriageway (just over 4 miles of me driving it) i.e. if you keep the conditions right, you don't have to exceed even 40 mph for the ECU to do its own regen.
Note though, that in the Accord handbook, it does not specify the engine rpm, but IMO a constant 40 mph at around 1400 rpm, for several miles, might do it (you may need at least 10 miles, if you can't find anywhere safe at a constant 40 mph, try 50 mph, but do not exceed 50 mph)
For a bit more info read from #126 to #133 here
http://typeaccord.co.uk/forum/topic/1534-dpf-what-is-it/?p=215138
I'm not saying that you will be able to achieve anything, but if you do, I'm sure you will get a "buzz" out of it, and certainly do not waste any more money on "forced" regens in workshops.
