Just an update on fitting the new filter the car was 70% better.Carl as you said i have the same symptoms when i drive the car for the 1st time its ok.Then if i drive it again after say 20 min that's when the jerking starts.
Im thinking to myself is it all these sensors that are faulty or could it be just a mechanical fault.My gut instinct is still fuel related or something simple like a sticky throttle.Or could these cars just suffer bad turbo lag.
Thinking about it i brought the car on 12k and before the car was mapped i had the same symptoms but not as much/ so the map has not caused the problem just made it more noticeable.
I agree the remap has only highlighted it, I didn't have any jerking before, but on some days the car didn't feel as eager as other days (looking back I suspect that was the IMRC Solenoid, but the stock map hid it well)
As said previously after replacing the IMRC solenoid, things were noticeably better, apart from 2 tiny jerks just as it started to register on the temp gauge, but then it was fine. I got rid of this little annoyance for a little while by cleaning the MAF, MAP and IMRC Valve and the car ran like a dream, I was pre-empting the judder but it just didn't come.
Finally it started again so I re-cleaned the MAF, and reset the ECU, it would go for approx 100 miles then come back, so I put that down to the operating ranges being wider whilst the ECU re-learns. I would say though that it drove OK , no judders but just wasn't in the dream department!.
I then re-cleaned the MAP and did a more thorough job on the temp sensor part, again the car was driving much better, but it didn't take as long for the judder to return and seems to be a little more frequent.
This morning it drove fine after re-connecting the MAP sensor yesterday, although the Mrs noticed some jerking last night when she used the car.
I'm going to Costco in a moment, which is just up the road, but the sort of journey when the jerking will start when you start it for the second time, so see what happens.
In relation to whether it is just a mechanical fault or bad turbo lag, the only thing against this is that I have had the car running well post re-map and not everyone is complaining of this issue, although equally there are quite a few suffering with the issue.
Another thing is it does seem to be emphasised by the weather, wet days especially, on nice crisp cold days it runs fine, but this recent mildness (last day or so) it has happened more.
The sticky throttle is an interesting one as the TPS sensor has been mentioned on a few Hondatech sites concerning Acura, however against this in my case is sometimes don't get much of an issue.
in relation to changing just the filter on the IMRC solenoid, I noticed too that most of the issue had gone, certainly was not as violent etc.
