clearing a code does nothing, he must have done something else in 90 minutes. If the car was not moving when he had the HDS connected then I reckon he cleared codes and reset the fuel trims.danny35 said:Sorry for the confusion, the only reason that I mentioned the rough/underpowered drive later was that I didn't realise that the car was running underpowered and not as smooth until the mechanic reset the code. Only then could I feel the difference as originally, I thought it was just the way the car drove.
as Cliff says, that implies a remap, but a remap is not possible over the OBD port on this cardanny35 said:It is hard to describe. After he did whatever he did, the car was driving easier with less effort and felt more effortless. Now it still drives okay, but seems to need more power on the pedal to get up to speed and it feels a bit noisier and heavier, as if the car is workin harder to drive.
When I drive now, it feels more strenuous and noisier and harder work for the car. Maybe rough was not the best choice of words to describe itfreddofrog said:as Cliff says, that implies a remap, but a remap is not possible over the OBD port on this car
What did you mean by "rough" in #85 and #118 ???
Thanks for your input, re the steering issues, yesterday when I drove and did a sharp left turn the steering wheel was trying to force itself first left and then to the right. I will go for a alignment once I get the other issues sorted.wookie said:Just been reading through this thread first things I would do is check adjust valve clearances and replace fuel filter if it hasn't been done. Both should of been done on the 75k service. As for the tracking issue. The accords run best on 16s if you put17s or 18s it has more of a tendency to tram line. The tourers were worse for this.
my #48 (page 3) ..... "There are two sensors in the exhaust on this engine btw : LAF sensor (lean air-fuel, aka wideband), and a standard oxygen sensor (aka narrowband). OEM price for each is the same, £225. Part number for former is 36531RBB003, for latter is 36532RADL12"Cliffordski said:IF it's the O2 sensor there are two one either side of the cat I understand the primary one before the cat goes most often if so there are usually one or two on eBay second hand for reasonable money
http://www.ebay.co.uk/itm/Accord-Type-S-K24A3-K24-2004-Primary-O2-Lambda-Sensor-/371504553443?hash=item567f659de3:g:bLoAAOSw5ZBWQJb-
well in #85 it sounds as if the idle rpm keeps changing, any more detail on that ?danny35 said:When I drive now, it feels more strenuous and noisier and harder work for the car. Maybe rough was not the best choice of words to describe it
VC's have been mentioned several times alreadywookie said:Just been reading through this thread first things I would do is check adjust valve clearances and replace fuel filter if it hasn't been done. Both should of been done on the 75k service. As for the tracking issue. The accords run best on 16s if you put17s or 18s it has more of a tendency to tram line. The tourers were worse for this.
I think we've already been through most of this Steve ....basically it had full service history up to 75k which was 2 years and 10k miles agoStevearcade said:My two cents worth, for now, let's ignore the matter of the car feeling better for a short while after it went in to the garage and now it feels bad again. Let's focus on the rough drive and poor mpg as it is right now.
- As the codes have been cleared once, you now need to get them re-read - if the car's thrown a code, then there's your problem - if there's no code, you need to consider other things (or maybe consider them in conduction with the following - often poor mpg is several things combined)
It could be any or perhaps a combination of some of these factors, or something else entirely? But if you can rule out all of the above or at least most of them, then we're on our way.
- So how's the oil level? The 2.4 can drink up to a litre every 1000 miles. This sounds a lot, but it likes quite a thin, synthetic oil and the handbook says a litre every 1K is fine. When did you last check your oil? When did you last have an oil change?
- What condition is your air filter in?
- When was your fuel filter last replaced?
- When was the last time your valve clearances were checked?
- How many miles have your spark plugs done?
- Is the exhaust original and if so, is it blowing?
- Is anything under the car loose (like the engine under tray) and causing increased drag?
- Are all the wheel bearings original? How many miles have they done? Have the mechanic inspect the rotation and see if the bearings are good.
- Tyre condition & correct (or slightly higher than recommended) pressures?
- Tracking/Wheel Alignment?
- How's the auto box? Has it had a transmission fluid change lately?
- Do you ever notice excessive heat or a smell coming from your brakes? - the brakes, rear especially, are known to bind on the Accord
- Are there any signs of anything untoward in the engine bay? Any signs of fluid escaping from anywhere?
There was one for £13.49. Do they all scan the same codes?Cliffordski said:Yes that's the sort of thing, although you can get them cheaper.
Hang in there, changing a sensor or filter is small beer at the end of the day.
possibly, depending on what it means by "view live data stream" (I think that some of them just literally record it all, then you have to load it into a laptop/PC and use software to replay it, but this one might let you choose one item for the display)danny35 said:Hi Brian, I think the one on the link also displays live readings. It says that it can also be plugged it while driving for readings.
